Date/Time: Sat, 04 Jul 2026 22:52:18 +0000
Volume at Price Threshold Alert V2
View Count: 1188
| [2022-03-07 21:42:01] |
| User486817 - Posts: 83 |
hello, i currently have the volume at price threshold alert on my number bar chart with pullback data enabled. the volume at price threshold alert v2 study works as expected on the main bar, however, i would like to enable this study to send alerts when an imbalance is detected in the pullback column. currently, it does not send alerts if an imbalance is detected in the pullback column, but does if in the main bar only. is there a way to enable the volume at price threshold alert v2 study to send alerts if an imbalance is detected in the pullback column? thank you for your help. kindest regards, |
| [2022-03-07 22:14:02] |
| John - SC Support - Posts: 47017 |
This would be a Feature Enhancement as the Volume by Price Threshold Alert V2 does not check the Pullback Column.
| [2022-03-07 22:46:39] |
hello john, is this something Sierra Charts is looking to add? i think it is worthwhile, particularly if the study has a "check pullback column Y/N?" switch in the study settings. is there a way to get this feature added? or would i need to get a custom study created by a professional? kindest regards, |
| [2022-03-07 23:06:13] |
We have tagged this as a Feature Request, which simply means that we understand the request and it is something we deem as a reasonable change. But, we do not know when or if we will get to making this change. Therefore, if this is something that you feel you need for your trading purposes, then you would be best to find someone to create a study for you that does what you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-07 23:14:22] |
hello john, thank you for the reply. i'll wait as i feel the native studies/features always work the best and are optimized in my experience. you all really do exceptional work all around. thank you for your time. kindest regards, |
