Date/Time: Sun, 09 Mar 2025 12:46:01 +0000
Chart showing delayed data
View Count: 469
[2022-03-07 17:53:42]
OneDayAtATime - Posts: 1
Hello I am trying to figure out what else I need to do in order to not have delayed data. I am looking at a footprint chart for ES but it is delayed. Can you please help me to figure out what else I need to do in order to not have delayed data.
Thank You
[2022-03-07 17:58:35]
Sierra_Chart Engineering - Posts: 18694
The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
Consider the above solution to avoid this problem in the future.
