Date/Time: Sun, 09 Mar 2025 21:08:13 +0000
How to keep Chart Range Bars at a Fix Position from Edge of Chart
View Count: 622
[2022-03-07 16:25:53]
User643426 - Posts: 127
Is there a way to keep Chart Range bars 1-2 inches from the edge of the chart so the new range bars that are formed don't obstruct my studies and moving averages? Thank you
[2022-03-07 18:36:29]
John - SC Support - Posts: 38516
We are not sure exactly what you are looking for as most studies do not draw into the fill space, but take a look at the following setting:
General Settings Window: Allow New Data In Unlocked Fill Space (Global Settings >> General Settings >> Charts >> Charts)
Also refer to the following regarding locking the fill space:
Working With Charts: Right Side Fill Space
[2022-03-08 18:13:14]
Whenever I adjust my DOM the scale of my other charts (footprint and Heatmap) also changes. How do I stop that so when I move the DOM it doesn't affect other charts?
[2022-03-08 18:44:06]
The implication from what you are stating is that you have the charts linked and the Scale setting in particular is setup to be the same between them. Refer to the information here:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber
