Date/Time: Wed, 23 Sep 2026 23:44:41 +0000
Getting Error when trying to change time frames
View Count: 836
[2022-03-07 14:58:46]
ssangha84 - Posts: 132
Whenever I try to click any of my time frame buttons on sierra chart, or manually enter a new time frame I am getting the following message: "You have performed an operation which cannot be completed because this chart is being referenced by studies in other charts in the Chartbook. Do you want to clear those references?"
Whether I click Yes or No, nothing changes, and it just stays on the same time frame. What would be the reason for this?
[2022-03-07 18:18:52]
John - SC Support - Posts: 47994
You have a study on the chart that is referencing another chart for which it requires the same time information. You will need to remove that study from the chart. Refer to the information here:
Unable to Change the Bar Time Period for Charts: Chart Being Referenced by Another Chart Preventing Bar Time Period Change
