Date/Time: Sun, 09 Mar 2025 12:49:48 +0000
VBP on Dom
View Count: 745
[2022-03-07 13:50:24] |
User894546 - Posts: 47 |
Hi The VBP on my Dom does not show the true volume at each price. Vol bar calculation method is set to Total Volume. Are there other settings needed to see just the total volume at each price? Also, I have tried to set a time for the vbp to reset (8.30 US) but it does not reset. Could you please help me with this too? Many THanks |
[2022-03-07 14:17:29] |
We are not totally sure what the issue is. What is the Days to Load setting in Chart >> Chart Settings set to? Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-07 14:25:59] |
I have changed to tick by tick and that seems ok now. I have 2 days to load. What settings do I need to restart the dom vbp at us open? Thanks again |
[2022-03-07 18:16:58] |
John - SC Support - Posts: 38516 |
There are not many options for the Volume Graph Period Type when the VbP is put on a Trading DOM. One of the available options (and the default) is From Session Start Time to End. As long as your session starts are the US Open, then you will get what you want. Refer to the information here: Volume By Price Study: Volume Graph Period Type For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
