Date/Time: Sat, 05 Apr 2025 00:57:43 +0000
CME Group and other Data Timestamp vs Timezone
View Count: 1045
[2022-03-07 08:25:45] |
User92573 - Posts: 559 |
Dear Support I've read the above and other pages but I just wanted a short confirmation as to whether the stored tick data is timestamped with the source-time (exchange) as one would assume or the local/destination time (computer time-zone)? I appreciate you are busy but any clarification would be gratefully received. Many thanks. |
[2022-03-07 08:37:01] |
User431178 - Posts: 634 |
Intraday Data File Format: DateTime This Date and Time value is and must be in the UTC time zone.
[2022-03-07 09:09:11] |
Yes the documentation referred to is correct. Refer to that.
[2022-03-07 09:18:24] |
I'll ask again as I don't think the question it was read. Dear Support I've read the above and other pages but I just wanted a short confirmation as to whether the stored tick-data is time-stamped with the source-time (exchange) as one would assume, or the local/destination time (computer set time-zone)? I appreciate you are busy but any clarification would be gratefully received. (Put simply, which one is it?) Many thanks. |
[2022-03-07 09:22:02] |
With Sierra Chart provided data feeds, the time stamping originates from the remote data source. In most cases this is the case. An exception would be Interactive Brokers which uses the local time stamp adjusted to UTC.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-07 09:22:26
[2022-03-07 13:57:08] |
Brilliant, thank you. Just what I was hoping for. Many thanks. |
