Date/Time: Fri, 11 Sep 2026 12:46:51 +0000
VIX
View Count: 765
| [2022-03-07 01:45:42] |
| User841161 - Posts: 346 |
With my current subscriptions, can I get data for the VIX market volatility Index.
| [2022-03-07 17:13:02] |
| John - SC Support - Posts: 47841 |
The index itself is available through our Sierra Chart Exchange Data Feed. You will need to follow the instructions at the following link and then enable the CBOE Indices exchange to get the data for $VIX: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions If you prefer, you can get data for the VIX Futures by enabling the CFE Exchange that is part of the Denali Exchange Data Feed by following these instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
