Date/Time: Sun, 09 Mar 2025 20:32:46 +0000
Point & Figure Charts - Wyckoff convention
View Count: 981
[2022-03-06 22:59:44] |
User629461 - Posts: 184 |
Is there an option to plot P&F charts using the Wyckoff convention (where there must be a minimum of 2 figures in each column before starting a new column rather than a new column for each direction change - e.g. when plotting a 1 box reversal chart)?
[2022-03-07 00:55:27] |
58LesPaul - Posts: 429 |
Ive been trying to create a Wyckoff P&F chart for a while and I haven't had any luck.
[2022-03-07 09:39:09] |
There is a Point and Figure chart study which can be modified to meet your requirements. We are just too busy to be working on this ourselves right now. Refer to the documentation here: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies Should not be difficult to add a condition to the existing code for what you are looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-07 09:39:25
[2022-03-08 16:32:06] |
User629461, how are you currently setting up your P&F charts? Are you using the study? Are you able to project moves accurately? I’ve tried about everything and can’t get anything consistent. Thanks |
