Date/Time: Sun, 09 Mar 2025 20:42:26 +0000
Auto close open orders
View Count: 551
[2022-03-06 19:49:14] |
User781621 - Posts: 5 |
Is there a way to set up the DOM so that when I close an open position all open orders for that symbol are cancelled? Other than using the Flat Button.
[2022-03-07 23:29:19] |
Sierra_Chart Engineering - Posts: 18714 |
Refer to: Basic Trading and the Trade Window: Main/C >> Menu >> Orders >> Cancel Orders on Flat Position (chart specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
