Date/Time: Tue, 26 Nov 2024 07:01:43 +0000
OEC Currency Continous Futures Contract?
View Count: 1485
[2014-04-17 18:20:26]
User70000 - Posts: 4
Is there a date when the continous contract data is going to be re-enabled? I tried to re-enable at it's still not working for me.
Todd
[2014-04-17 18:32:26]
We solved problem with OEC and Continuous Futures Contracts for currency futures about two weeks ago.
You must update Sierra Chart to the latest release. Update with Help >> Download Current Version.
The problems that users were experiencing with the OEC FIX connection were resolved by OEC. So it is OK to update.
[2014-04-17 18:44:52]
Thanks that worked, appreciate the quick response.
-Todd
[2014-04-17 19:47:15]
Spoke to soon. When I enable continous contract all the data shows up until 3/13 only, can't seem to get any data past 3/13. Tried deleting/downloading data without any luck. Not sure if I have an incorrect setting or what. The is on the 6E only, data for NQ is correct and all the settings are the same.
-Todd
Date Time Of Last Edit: 2014-04-17 19:53:54
[2014-04-17 23:15:19]
What is the exact symbol of the chart? Make sure it is the June 2014 contract.
Try re-downloading all the data by following these instructions:
http://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading
[2014-04-17 23:57:43]
Ok that did it. Had to do a reload and recalculate, then delete and download. All is good now.
Thanks for the help
Todd
