Date/Time: Sun, 09 Mar 2025 20:43:00 +0000
Problem sending orders using keyboard shortcuts
View Count: 532
[2022-03-04 15:24:27]
User447447 - Posts: 3
Hi I'm a new Sierra user and I'm struggling trying to find a simple way to perform two actions that I use on other platforms:
1. How can I perform simultaneously 2 actions (for example orders) using a keyboard shortcut? I'm using the "Custom Trading Keyboard Shortcuts" but it only allows one order per each hotkey.
2. If the above is not available, how can I send an order with attached orders (triggered orders) using the Keyboard and not just the main Trade panel?
Any help will be appreciated. Thank you!
[2022-03-07 17:03:25]
1. What two actions do you want to perform?
2. Just configure a keyboard shortcut, for what you want to do. Instructions:
Basic Trading and the Trade Window: Trading Keyboard Shortcuts
Or:
Basic Trading and the Trade Window: Custom Trading Keyboard Shortcuts
And configure the Attached Orders:
Attached Orders: Using Attached Orders and Attached Order Settings
Date Time Of Last Edit: 2022-03-07 17:03:45
[2022-03-08 17:43:03]
Thanks for the reply.
For example, I want to have a shortcut key with a buy limit order at price "Bid - 20 ticks" which if triggered, automatically sends two child orders: 1) a market stop order at price "Bid - 40 ticks", and 2) a profit target at "Bid + 80 ticks".
That could be a good example of what I'm unable to accomplish.
Thank you!
