Date/Time: Sun, 09 Mar 2025 13:04:49 +0000
[STRATEGY][AUTOMATE] How to automate my strategy into Sierrachart ?
View Count: 1283
[2022-03-05 15:25:08]
Sawtooth - Posts: 4181
My only problem is that I dont have columns lefts for making more persistent variable
You can set the 'Number of Formula Columns' to a max of 60.
[2022-03-05 15:57:44]
noaah - Posts: 32
That's right ! Thanks you !
Now trying to show the Exit Candle with an arrow..
[2022-03-05 16:17:39]
noaah - Posts: 32
@tomgilb I found out your solution on an other post but can't made it works, it tell me SYNTAX error, I probably miss something but I will persist 'cause your solution to show the exit candle look so smart !
Here the screenshot:
ID4 is my Position Quantity Study and ID7 my spreadsheet automated study :)
Because yes, I dont really care about showing the exact exit price, I just want to point out with an arrow the exit bar like the entry bar to visualize quickly my trades !
Date Time Of Last Edit: 2022-03-05 16:20:59
imageCapture d’écran 2022-03-05 à 17.15.20.png / V - Attached On 2022-03-05 16:17:05 UTC - Size: 153.47 KB - 140 views
[2022-03-05 16:34:02]
The formula in the pic is Simple Alert syntax; change it to spreadsheet syntax:
In AA3:
=IF(ID4.SG1@3<>ID4.SG1@4,E3,AA4)
[2022-03-05 17:01:56]
noaah - Posts: 32
Yes thanks got it ! I can now see when the value change !
Will I be able to show the Buy Exit / Sell Exit arrow in the chart with that ?
imageCapture d’écran 2022-03-05 à 18.00.47.png / V - Attached On 2022-03-05 17:01:51 UTC - Size: 141.76 KB - 140 views
