Date/Time: Mon, 05 Oct 2026 21:51:12 +0000
[Locked] - Custom Studies not appearing in Sierra Chart
View Count: 2991
[2022-03-15 13:14:55]
We finally have some good information here. We need to study this and examine the code and figure out what is happening.
[2022-03-17 11:27:55]
Mark Sear - Posts: 43
Hi there,
Any update?
Many thanks
[2022-03-17 12:47:46]
We need to add additional logging to isolate the issue further. We simply cannot reproduce using the files you have zipped up. So we really do not know what is going on still in your case.
[2022-03-17 13:16:00]
Is there anything else we could try at this end that might help speed up your analytics?
[2022-03-17 13:55:08]
No. We have added the additional logging already and we can put out a new release in a couple of hours.
[2022-03-17 17:31:12]
We have made a release of 2370. Update to that prerelease:
And then provide us the Message Log again using the previously described method.
Date Time Of Last Edit: 2022-03-17 17:31:41
[2022-03-18 14:40:06]
Do you still need help with this? Did the additional logging give you an indication of what the problem is?
[2022-03-18 16:40:15]
yes i do. Here's the log.
Reading Internal Order ID file. | 2022-03-18 16:38:48.950
Reading Trade Orders file. | 2022-03-18 16:38:49.042
Reading Trade Positions file. | 2022-03-18 16:38:49.042
Reading Trade Account Data files. | 2022-03-18 16:38:49.043
UDPListener (1572). Port 22904 | Listening on UDP port 22904. | 2022-03-18 16:38:49.065
Software version: 2371 64-bit | 2022-03-18 16:38:49.065
Primary Thread ID: 13404 | 2022-03-18 16:38:49.065
Usage end date: 2022-06-17 | 2022-03-18 16:38:49.065
Enabled for: Sierra Chart Historical Data Service. | 2022-03-18 16:38:49.065
Enabled for: Delayed Denali Exchange Data Feed. | 2022-03-18 16:38:49.065
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-03-18 16:38:49.065
Current selected Data/Trading service: SC Data - All Services | 2022-03-18 16:38:49.065
Custom symbol settings values: enabled | 2022-03-18 16:38:49.065
Chart Update Interval: 500 | 2022-03-18 16:38:49.065
Intraday Data Storage Time Unit: 1 | 2022-03-18 16:38:49.065
Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2022-03-18 16:38:49.065
2022-03-18 16:38:49 Local computer time in UTC | 2022-03-18 16:38:49.065
2022-03-18 16:38:49 Local computer time in SC Time Zone | 2022-03-18 16:38:49.065
2022-03-18 16:38:47 Server time in UTC | 2022-03-18 16:38:49.065
Local computer UTC time and Server UTC time difference: 1 seconds. | 2022-03-18 16:38:49.065
Program path: C:\SierraChart\ | 2022-03-18 16:38:49.065
Data Files path: C:\SierraChart\Data\ | 2022-03-18 16:38:49.065
OS Version Number: 10.0 | 2022-03-18 16:38:49.065
Locale Setting: C | 2022-03-18 16:38:49.065
DLLs: Enigma-Inteligex-Lite_64.dll, Enigma-Inteligex-MarketMomentum_64.dll, Enigma-Inteligex_64.dll, Inteligex_64.dll, UserContributedStudies_64.dll | 2022-03-18 16:38:49.065
Allowed protected custom studies: Enigma-Inteligex, Enigma-Inteligex Lite, Enigma-Inteligex Market Momentum, Enigma-Inteligex Pro, Inteligex, Inteligex-DiamondV2 | 2022-03-18 16:38:49.065
Crash reporter started: true | 2022-03-18 16:38:49.065
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2022-03-18 16:38:49.084
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-03-18 16:38:49.128
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-03-18 16:38:49.180
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-03-18 16:38:49.180
Received 5 login tokens. | 2022-03-18 16:38:49.257
Symbol settings MD5 received. Request ID: 1. | 2022-03-18 16:38:50.817
Requested symbol settings for service code scdataallservices. Request ID: 2. | 2022-03-18 16:38:50.817
Symbol settings received. Request ID: 2. | 2022-03-18 16:38:53.158
Files to Open on Startup | Opening file: ExampleChartbook.cht | 2022-03-18 16:38:53.444
The Chartbook file is not a valid Chartbook. File: C:\SierraChart\Data\ExampleChartbook.cht | 2022-03-18 16:38:53.445 *
SC Data - All Services | Connected to server complete. | 2022-03-18 16:38:55.442
Triggering next historical data download in queue. | 2022-03-18 16:38:55.442
No download requests in the queue to start downloads for. | 2022-03-18 16:38:55.446
MESM22-CME 3 Min #1 | Reloading chart. | 2022-03-18 16:39:08.981
Mapping MESM22-CME to MESM22. Service code: cme | 2022-03-18 16:39:09.481
Using symbol data fast lookup vector | 2022-03-18 16:39:09.481
SC DTC Delayed Exchange Data | Starting real-time market data updates for: MESM22-CME (MESM22). ID: 1 Service code: cme | 2022-03-18 16:39:09.481
SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10043 | 2022-03-18 16:39:09.481
SC DTC Delayed Exchange Data | Requesting security definition data for: MESM22-CME (MESM22). ID: 1 | 2022-03-18 16:39:09.481
Starting DelayedDownloadMonitoringTimer | 2022-03-18 16:39:09.481
Starting HDTimeoutTimer | 2022-03-18 16:39:09.481
Added historical Intraday data request for MESM22-CME to the queue. | 2022-03-18 16:39:09.482
Intraday data recording state for symbol MESM22-CME is set to download 'Pending'. | 2022-03-18 16:39:09.482
Triggering next historical data download in queue. | 2022-03-18 16:39:09.482
Delaying start of download for MESM22-CME | 2022-03-18 16:39:09.493
DTC Client socket (1) | Creating socket. | 2022-03-18 16:39:09.497
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-03-18 16:39:09.497
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-03-18 16:39:09.497
SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-03-18 16:39:09.657
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-03-18 16:39:09.657
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-03-18 16:39:09.658
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-03-18 16:39:09.841
SC DTC Delayed Exchange Data | Sending logon request message. | 2022-03-18 16:39:09.841
SC DTC Delayed Exchange Data | Received logon response. | 2022-03-18 16:39:10.524
SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-03-18 16:39:10.524
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-03-18 16:39:10.524
SC DTC Delayed Exchange Data | Successfully connected. | 2022-03-18 16:39:10.524
SC DTC Delayed Exchange Data | Trading is not supported. | 2022-03-18 16:39:10.524
SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MESM22-CME -> MESM22 | 2022-03-18 16:39:10.524
SC DTC Delayed Exchange Data | Received security definition for symbol MESM22-CME | 2022-03-18 16:39:10.745
HD Request # 1 | Downloading Intraday chart data for MESM22-CME to the file MESM22-CME.scid. Service: cme | 2022-03-18 16:39:15.474
HD Request # 1 | Download start date-time: 2022-03-15 10:16:30.000000. File last date-time: 2022-03-15 10:16:30.000000 | 2022-03-18 16:39:15.476
HD Request # 1 | Using server: ds21.sierracharts.com port 10150 | 2022-03-18 16:39:15.476
Socket (2) | Creating socket. | 2022-03-18 16:39:15.477
Socket (2) | New receive buffer size: 5242880 | 2022-03-18 16:39:15.477
Socket (2) | Connecting to IP: 216.1.90.129. | 2022-03-18 16:39:15.477
HD Request # 1 | Setting DTC encoding to Binary VLS | 2022-03-18 16:39:15.757
HD Request # 1 | Sending historical data logon request message. | 2022-03-18 16:39:15.757
HD Request # 1 | Requesting Intraday data. Start date-time: 2022-03-15 10:16:30. Record interval: 1. Symbol: MESM22 | 2022-03-18 16:39:16.334
HD Request # 1 | Decompressing data. | 2022-03-18 16:39:16.456
HD Request # 1 | Receiving Intraday data for MESM22-CME starting at 2022-03-15 10:16:30.004000 | 2022-03-18 16:39:16.996
HD Request # 1 | Timestamp of first Intraday data file record written: 2022-03-15 10:16:30.004000 | 2022-03-18 16:39:17.479
Socket (2) | CloseSocket call. | 2022-03-18 16:39:20.582
Historical data download thread signaled to stop. | 2022-03-18 16:39:20.582
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-03-18 16:39:20.582
HD Request # 1 | Received 178903 Intraday data records from 2022-03-15 10:16:30.004000 to 2022-03-18 16:29:18.340000 (3.3 days) and wrote 178903 records for MESM22-CME | 2022-03-18 16:39:20.582
HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2022-03-18 16:29:18.340000 | 2022-03-18 16:39:20.582
HD Request # 1 | Completion time: 5s | 2022-03-18 16:39:20.583
HD Request # 1 | Intraday data download complete for MESM22-CME. Unique request ID: 1 | 2022-03-18 16:39:20.583
Removing historical data download ID 1. | 2022-03-18 16:39:20.583
Real-time Intraday chart data file updates started for MESM22-CME | 2022-03-18 16:39:20.583
Opened cached Intraday file: C:\SierraChart\Data\MESM22-CME.scid. Thread ID: 13404 | 2022-03-18 16:39:20.583
Intraday chart data file opened for MESM22-CME | 2022-03-18 16:39:20.583
HD Request # 1 | Enabling Intraday chart updating for symbol. | 2022-03-18 16:39:20.583
Triggering next historical data download in queue. | 2022-03-18 16:39:20.583
No download requests in the queue to start downloads for. | 2022-03-18 16:39:20.583
Socket (2) | Socket gracefully closed by remote side. | 2022-03-18 16:39:20.702
Socket (2) | Closed. | 2022-03-18 16:39:20.702
Found DLL: Enigma-Inteligex-Lite_64.dll | 2022-03-18 16:39:30.947
Found DLL: Enigma-Inteligex-MarketMomentum_64.dll | 2022-03-18 16:39:30.947
Found DLL: Enigma-Inteligex_64.dll | 2022-03-18 16:39:30.947
Found DLL: Inteligex_64.dll | 2022-03-18 16:39:30.947
Found DLL: UserContributedStudies_64.dll | 2022-03-18 16:39:30.947
Loading DLL: C:\SierraChart\Data\Enigma-Inteligex-Lite.dll (Enigma-Inteligex-Lite_64.dll). Handle: 7ff83c9f0000 | 2022-03-18 16:39:30.953
Loading DLL: C:\SierraChart\Data\Enigma-Inteligex-MarketMomentum.dll (Enigma-Inteligex-MarketMomentum_64.dll). Handle: 7ff83b040000 | 2022-03-18 16:39:30.959
Loading DLL: C:\SierraChart\Data\Enigma-Inteligex.dll (Enigma-Inteligex_64.dll). Handle: 7ff8376d0000 | 2022-03-18 16:39:30.965
Inteligex_64.dll loading error. Windows error code 126: The specified module could not be found. | 2022-03-18 16:39:30.968
VersionNumber is 0 for Inteligex_64.dll | 2022-03-18 16:39:30.968
InternalVersionNumberToFileNameMap is empty for Inteligex | 2022-03-18 16:39:30.968 *
Closest match search for: C:\SierraChart\Data\Inteligex.dll returned empty result. | 2022-03-18 16:39:30.968 *
Loading DLL: C:\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffffeb70000 | 2022-03-18 16:39:30.977
[2022-03-18 17:07:46]
User99735 - Posts: 234
Error 126 - could be caused by a missing dynamic link library(DLL)
a) If you are using 'other' version of VC++ ( not installed via Sierra ), ensure the redistributable for the 'other' Visual Studio version is installed.
b) If some other non-standard dll's are referenced in Inteligex_64.dll, the dll should be copied to one of standard folders ie C:\Windows\System32 or Sierra's data folder, or the path of the dll should be added to environment PATH
[2022-03-21 23:11:35]
The answer at post #33 is correct. We do not know the cause of this, but this is definitely the reason for the issue:
Date Time Of Last Edit: 2022-03-21 23:12:43
[2022-03-22 09:23:24]
We've manage to recreate the file and reload the file and it now works.
[2022-10-04 18:46:57]
opmetal - Posts: 74
I'm having the same issue, Windows error code 126 trying to load a dll on a remote VPS. Same SC version 2443 on both my home and remote servers. The only difference is Windows version (Win 10 at home, Win Server 2016 on VPS). Message log:
Found DLL: UserContributedStudies_64.dll | 2022-10-04 10:52:47.871
Found DLL: Zero Dark 40 [DEV].dll | 2022-10-04 10:52:47.871
Loading DLL: C:\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ff883200000 | 2022-10-04 10:52:47.961
Zero Dark 40 [DEV].dll loading error. Windows error code 126: The specified module could not be found. | 2022-10-04 10:52:47.973
VersionNumber is 0 for Zero Dark 40 [DEV].dll | 2022-10-04 10:52:47.973
InternalVersionNumberToFileNameMap is empty for Zero Dark 40 [DEV] | 2022-10-04 10:52:47.973
Closest match search for: C:\SierraChart\Data\Zero Dark 40 [DEV].dll returned empty result. | 2022-10-04 10:52:47.973
FYI I compiled the dll locally on the VPS and that worked but this is just a workaround.
Date Time Of Last Edit: 2022-10-04 21:17:06
[2022-10-05 17:17:53]
Sierra_Chart Engineering - Posts: 25065
Refer to the documentation here for this:
How to Use an Advanced Custom Study or a Study Collection: Advanced Custom Study Errors
