Date/Time: Sun, 09 Mar 2025 12:44:38 +0000
Removing milliseconds from Compact Tool Values Window
View Count: 455
[2022-03-04 11:26:11] |
User21243 - Posts: 48 |
Can't seem to figure out how to remove milliseconds from the compact tool values window. See attached pic. Thanks. |
[2022-03-04 11:57:38] |
What we will do is if it is all zeros, it will not be shown in this case.
