Date/Time: Sat, 19 Sep 2026 18:53:26 +0000
Scroll Wheel List
View Count: 887
| [2022-03-04 07:16:21] |
| Acro - Posts: 459 |
Hello, It would be wonderful if there was one more option in the scroll wheel list settings in Global Settings - General Settings. Per the attached screenshot, if there was an inverse of one of existing options so that: Scroll Wheel Changes Spacing and With Shift Scrolls Vertical Scale That would help enormously if using Sierra in cconjunction with another application like Tradingview/Bookmap etc as it would mean your brain would basically learn one muscle memory that worked almost excactly across several typical trading apps |
| [2022-03-07 23:03:16] |
| Sierra_Chart Engineering - Posts: 24890 |
We will add this.
