Date/Time: Tue, 11 Mar 2025 17:03:38 +0000
line to separate start of day session
View Count: 916
[2022-03-04 05:50:36] |
Shawn Washington - Posts: 10 |
Is there a way to put a vertical line to separate overnight session from day session? And is there a way to do the same to separate end of week close?
[2022-03-04 06:32:21] |
Tonkadad - Posts: 235 |
Time Line study Just change the time to your time on charts. i.e. I am 5 hours behind EST that's why it's 04:29 which = 9:29 am (1 min before market open) Date Time Of Last Edit: 2022-03-04 06:40:29
[2022-04-29 05:19:48] |
Refer to the Vertical Grid setting: Chart Menu: Vertical Grid (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
