Date/Time: Sun, 09 Mar 2025 13:11:04 +0000
NASDAQ Total View without Futures data
View Count: 486
[2022-03-03 21:48:47] |
User763002 - Posts: 30 |
Hello, I am looking to see if I still need a funded futures account to access only the Nasdaq total view data through sierra chart? I will not be needing any of the futures data as I am only trading equities at this point. Thank you |
[2022-03-03 21:49:47] |
John - SC Support - Posts: 38516 |
You do not need a funded trading account to be able to get the NASDAQ TotalView data. That requirement is just for the CME Group data. Follow these instructions to setup the NASDAQ TotalView data: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* Also, be sure you Deactivate the CME Group exchanges if you do not need them. You can do this from the following page: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-03 21:51:24
