Date/Time: Tue, 26 Nov 2024 06:43:25 +0000
Using Automated Strategy and disconnections
View Count: 937
[2014-04-17 16:15:28]
SHCM - Posts: 20
Is there a way to make a custom DLL automated strategy continue to work after the platform has been disconnected and then reconnected? Occasionally the platform will lose connection and then the automation is lost at that point. If there was a way to turn it back on with the current orders in the market that would be great. Right now if I lose connection I have to manually modify the orders.
[2014-04-17 17:50:21]
An automated trading system will continue to run when the data feed is reconnected. This is for certain. the only thing in Sierra Chart which would disable this is Trade >>Auto Trading Enabled.
As far as what specific problem you are having, we do not know and you will have to work that out yourself.
