Date/Time: Sun, 09 Mar 2025 12:51:31 +0000
Auto Liquidation Liability Release
View Count: 617
[2022-03-03 18:12:53] |
bdunn - Posts: 19 |
I cannot fill out the signature line on the form for Auto Liquidation Liability Release. It doesn't let me type anything. I have tried different computers and browsers.
[2022-03-03 18:21:28] |
We will check this now.
[2022-03-03 18:25:38] |
We need to do a remote assistance session to look into this on your system. Make sure your current telephone number is set here and let us know when that is done: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-03 18:29:58] |
bdunn - Posts: 19 |
My number is correct.
[2022-03-03 22:23:21] |
The user was called.
Sierra Chart Support |
