Date/Time: Fri, 22 Nov 2024 02:27:09 +0000
Activate/Deactivate Alerts
View Count: 1761
[2013-04-25 14:56:38] |
User23815 - Posts: 210 |
New User. Is there a way to turn pre-set alerts on and off globally? I have alerts(text) set to function in studies and horizontal lines, but only want them to send the alerts when I am trading. Trading times vary so I prefer not to use time settings. If not, how is this best handled? Thanks
[2013-04-25 17:24:12] |
This is not supported. Longer-term we do plan to add this capability but it will be a while before we get to it.
