Date/Time: Sun, 09 Mar 2025 13:13:40 +0000
New to Sierra, Question on what is needed
View Count: 478
[2022-03-03 15:39:10]
SlothicTrader - Posts: 6
I would like to be able to get real-time data on futures, equities and the vix. I'm a non-professional trader with accounts at other brokerages that I execute with. I would like to use Sierra Chart for advanced charting with emphasis on TPO charts. I'm a bit confused as to what packages or data feeds I need. One of the options I found says it requires a funded trading account Sierra supports.
Is it possible to get the above real-time data and what packages or data feeds for my use and specifically what is recommended?
Thank you
[2022-03-03 16:44:14]
John - SC Support - Posts: 38516
Which Futures exchanges do you want data for?
If you require data for the CME Group, then they require that you have a live, funded, futures trading account in order to qualify for the non-professional exchange fees. For more information on this topic, refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
With regards to the VIX are you wanting data for the VIX Index or the VIX futures?
