Date/Time: Sun, 09 Mar 2025 13:12:15 +0000
[Programming Help] - problem to find formula
View Count: 466
[2022-03-03 07:52:04] |
User278398 - Posts: 291 |
hello all, i'm trying to build formula which give me a specific value (in high,low,close,open) in specific study... for example for LOW bar i'm trying get the value from ID1.SG1 study. how i need to write the correct formula? thank u. |
[2022-03-03 15:13:46] |
So you want to know the value of a study at the bar low? To do this, requires that you use this study: Study Overlay - OHLC (Open, High, Low, Close) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
