Date/Time: Sun, 09 Mar 2025 21:08:12 +0000
Custom Menu Item Name - don't update on detachted charts
View Count: 539
[2022-03-02 19:40:48] |
TGK4711 - Posts: 17 |
"Customize Menu Items" -> "Custom Menu Item Name" don't update automatically on detached charts. Charts have to attach and detach again to update "Custom Menu Item Name". (Maybe works as aspected, not possible or I didn't found the info in docu?) Version 2253 Thx |
[2022-03-11 15:26:36] |
We have added support for this in the latest release. However, this limitation has been known and a restart has been required for those menus to update. For some menus to update a restart is required. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
