Date/Time: Mon, 05 Oct 2026 06:09:04 +0000
Incorrect number of lot in Sim mode
View Count: 788
| [2022-03-02 17:32:25] |
| User468483 - Posts: 12 |
Hi, When I take an order in Sim, even if I select 1 lot, it takes 63247 lots and every tick count for more than 600 points. I download the most recent version and I have the same thing. What's wrong ? Thanks Date Time Of Last Edit: 2022-03-02 17:32:52
| [2022-03-02 21:20:46] |
| John - SC Support - Posts: 48095 |
What is the symbol for which you are making the trade? What value is being set to 63247? Is this the quantity of the order or something else? Can you give us a screenshot showing the value in use? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-03 07:33:45] |
Hello, I'm trading BUND on EUREX. 63247 is the number of contract put on the market when I buy or sell as you can see on the screenhot enclosed. No matter if I select 1, 2 or 10 contracts, it entrer 63247 contarct. On real account, it's the same thing but order is rejected because too high. https://www.sierrachart.com/image.php?Image=1646292936865.png https://www.sierrachart.com/image.php?Image=1646292982502.png Date Time Of Last Edit: 2022-03-03 07:36:31
| [2022-03-03 10:48:33] |
to complete the answer, I have 2 instances of SC, the main one with the Bund, and a 2sd one with ES. The 2sd one works fine and the number of lot is correct. But if I put ES on the main instance, I have the same problem with 63427 lots at every order |
| [2022-03-03 11:43:07] |
The problem seems to be solved. It cames from the DOM. I deleted it and put a new one. It seems to be ok Thanks |
| [2022-03-03 15:14:21] |
The issue that you experienced is explained here: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM (Trade Window Settings Not Applying to Chart or Trading DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-03 15:14:33
