Date/Time: Mon, 10 Mar 2025 10:22:10 +0000
Connecting multiple accounts
View Count: 537
[2022-03-02 15:48:32] |
maliik3103 - Posts: 48 |
hi when i use order allocation to trade, and have attached orders on, so when i place a trade it automatically places a TP and SL , but when i move the SL on one account that is connected to the second , the SL only moves on the first account , so i have to manually go to the second account and move that SL as well, is there a way to connect the attached orders so if i move it on one account, it also moves on the second
[2022-03-02 16:33:59] |
This will be supported in an upcoming release in the next two weeks. It is not yet supported.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-02 16:34:08
[2022-03-28 07:54:57] |
is it supported now on the 2368 version ?
[2022-03-28 08:25:33] |
In version 2376. Refer to: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
