Date/Time: Tue, 26 Nov 2024 06:50:51 +0000
ILQ-Velocity to Advantage CQG
View Count: 1171
[2014-04-17 12:50:17] |
OneTic - Posts: 2 |
I can't log in Sierra Chart, just get 'Invalid Account or Password'. I have talked with Advantage and was told I need to contact you. Old Velocity login won't work to bring up SC to chage server settings.
[2014-04-17 17:33:11] |
We have reset your Sierra Chart charting and trading software password. It has been sent in a separate e-mail to your e-mail address. If you did not receive it, please let us know. Your e-mail provider may have filtered the message and placed it in a junk mail folder. For complete login instructions and help with possible login problems, please see: http://www.sierrachart.com/index.php?l=LoginInstructions.php If you continue to have a problem logging in, then please let us know and provide us with the EXACT error message you see after pressing the Login button. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-17 17:33:25] |
I can log to Sierra Chart with my old account and password, but when I change the server settings it doesn't work!
Provide us a copy of the Sierra Chart Message Log, by following these instructions:https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-17 18:54:33] |
Contact your broker and let them know you are getting this message: CQG FIX Trading: Received a Logout message. Text = Logon failed: Trader is not enabled to use FixService client application. Please contact your FCM. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
