Date/Time: Fri, 14 Mar 2025 12:14:43 +0000
Adding column background for pulling stacking and current trades
View Count: 745
[2022-03-02 12:34:47] |
User963221 - Posts: 20 |
I have set up my DOM like attached picture. I am trying to add a background to the pulling and stacking columns and also the current trades column. Any help would be greatly appreciated. I am coming from Jigsaw, so am used to having color in these columns. Also, is there a way to clear/reset these columns? How about a way to limit their depth , like only show pulling and stacking for a depth of 12. Thanks!! |
[2022-06-09 19:51:36] |
I am trying to add a background to the pulling and stacking columns and also the current trades column. There is no support for the background coloring those particular columns. We will have to add support for this.For clearing the columns there are several commands: Trade Menu: Clear Recent Bid/Ask Volume (Trade menu) How about a way to limit their depth , like only show pulling and stacking for a depth of 12. This is supported:Global Trade Settings Windows: Maximum Bid/Ask Market Depth Pulling/Stacking Levels (Global Settings >> Chart DOM Settings >> Other >> Other Settings) We have temporarily reactivated your account, if you want to do testing any of the above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-09 19:52:37
