Date/Time: Wed, 19 Mar 2025 18:47:36 +0000
[Locked] - Sharing Drawings Between Computers
View Count: 725
[2022-03-01 18:33:41] |
User964846 - Posts: 38 |
I am a small trader working with Sierra Charts. A friend and I, we are trading together, and we would like to be able to share drawings between computers. I saw this: What is Sierra Chart Working On | Post: 276169 Is there a time-table for when this is completed? Date Time Of Last Edit: 2022-03-01 18:46:15
[2022-03-01 19:09:54] |
Sierra_Chart Engineering - Posts: 18843 |
We hope to get started on this soon but no work has been done on this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-01 19:10:01
[2022-10-06 17:38:06] |
Hey Sierra. A few months ago, I asked if chart drawings could be shared between different computers. Yall had replied that Sierra was working on this. And I was wondering, if you all had begun or even finished the project. Thanks Sierra |
[2022-10-06 20:48:30] |
John - SC Support - Posts: 38806 |
It is still something we want to do, but we have not gotten to it yet.
[2022-10-30 22:32:18] |
JohnR - User831573 - Posts: 320 |
As a stop gap measure, You and your friend could use TeamViewer (or something like it). It is a program that some use for tech support. It allows you as a user to share your screen or part of one with someone else. If you wanted you cold also them them take over your computer or you take over theirs. I have used it with a friend to occasionally share a screen to show what I am working on or assist them with debugging code, and they have done the same. Hope this helps, JohnR |
