Date/Time: Wed, 19 Mar 2025 13:49:15 +0000
MBO Minimum Size settings
View Count: 893
[2022-03-01 15:19:56]
User148596 - Posts: 217
Hi, I've been looking for information on where to set the minimum lot size to be displayed for MBO and haven't been able to find it. Can you direct me to the right place?
Thanks!
[2022-03-01 15:27:35]
User907968 - Posts: 838
It is set per instrument in the symbol settings - Global Symbol Settings
Minimum Market by Order Quantity
[2022-09-14 17:37:37]
Hi, I have this setting set to 25 but I'm still getting values lesser than 25. I disconnected and reconnected my data feed and that didn't resolve the issue. Any help would be appreciated.
[2022-09-14 23:20:17]
John - SC Support - Posts: 38784
Are you using a "Trade and Current Quote Symbol"? If so, then you would need to set the minimum value for the symbol in that "Trade and Current Quote Symbol".
[2022-09-15 14:17:57]
Hi John, I am not using the trade and current quote symbol function so that doesn't appear to be the issue.
[2022-10-26 16:37:24]
Hi, this issue is still occurring. I have minimum market by order in global settings symbol settings set to 25 and I'm getting values less than that.
[2022-10-26 17:42:08]
What is the symbol of your chart and what is the symbol for which you entered the value?
Also, does the option for Use Custom Symbol Settings Values on the Custom Symbol Settings window have a checkmark next to it? Refer to the following:
Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings)
And finally, after you make a change to the symbols you need to select File >> Disconnect then File >> Connect to Data Feed in order for the changes to take affect.
[2022-10-26 18:10:54]
The symbol for the chart is F.US.EPZ22 and the symbol I entered the value for is F.US.EP?##.
Yes, the box is checked for Use custom symbol settings values.
I have disconnected and reconnected the data feed and I'm still getting values below my minimum setting.
[2022-10-26 19:06:40]
Sierra_Chart Engineering - Posts: 18841
You are running an older version of Sierra Chart. You must update to the current version. Instructions:
Refer to item number 11 here:
Important Notices 2022-05-05
Date Time Of Last Edit: 2022-10-26 19:08:55
