Date/Time: Thu, 28 Nov 2024 13:49:10 +0000
Data consistently stops loading onto chart
View Count: 703
[2022-03-01 14:03:39]
Greentea - Posts: 26
On sim, using Teton & Denali
For past few months: every 1 or 2 days data stop loading and need to reload charts. Annoying.
Is this normal? Never used to be
[2022-03-01 14:18:39]
We need to precisely understand this. Does the chart stop updating in real time?
Refer to all the possible chart updating issues here:
And what exactly are you doing for this?:
Are you selecting Chart >> Reload and Recalculate?
[2022-03-01 16:01:22]
Yes - candles stop being added to chart book on one ore more chart books at random times every 1 to 3 days
Yes - whatever missing is added and things work until this process repeats
[2022-03-01 16:11:12]
If this is really true, this is like a problem we saw back in the days of Windows 95/98. We have not seen anything like this since then. Based upon what we are hearing, the update timer from the operating system is no longer functioning.
Try restarting your computer system.
Make sure is it is not one of the other issues listed here:
Date Time Of Last Edit: 2022-03-01 16:32:25
[2022-03-02 18:56:30]
"Try restarting your computer system."
Done, did not solve the problem
"Make sure is it is not one of the other issues listed here:
Https://www.sierrachart.com/index.php?page=doc/helpdetails3.html"
Read through this and even updated symbol list and restarted SC but did not solve problem.
Problem occurred and still occurring until Edit > Edit/download data intraday chart or Delete and download data intraday chart) again 24 hours later, 3 different instruments affected so far, see pictures
One more detail: only affected daily charts, (all in each chartbook) and NOT historical charts(IE daily/weekly, etc - these keep drawing the candle)
imageUploadImage.png / V - Attached On 2022-03-02 18:38:05 UTC - Size: 32.46 KB - 118 views
imageUploadImage.png / V - Attached On 2022-03-02 18:53:11 UTC - Size: 36.14 KB - 122 views
[2022-03-03 01:32:50]
We are going to make one small change in the next version to see if it helps. There may have been a change we made to Intraday data file management which perhaps for an unknown reason in your case is causing an issue.
