Date/Time: Sun, 09 Mar 2025 01:27:51 +0000
How to reclaim my data
View Count: 467
[2022-02-28 23:23:15] |
Jason Tran - Posts: 10 |
Hello, My numbers charts have 0x0 ask bid. It showed the data a minute ago but I might've pressed something. Would you please help me retrieve the data back? https://www.sierrachart.com/image.php?Image=1646090526128.png Thank you |
[2022-02-28 23:30:46] |
John - SC Support - Posts: 38516 |
Most likely what you are seeing is simply due to your not being connected to the data feed during that time. Refer to the information regarding CQG historical data in the second bullet at the following link: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2351 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
