Date/Time: Sun, 09 Mar 2025 01:34:15 +0000
Purchased service pack 12 cannot be used
View Count: 432
[2022-02-28 15:31:47] |
User290040 - Posts: 1 |
1、 Purchased service pack 12 cannot be used 2、 open SC, no new Chartbook. How do I use other features, such as those in Service pack 5 |
[2022-02-28 16:41:22] |
What is it you specifically want to do? And then we will help you with that specifically. For example what symbol do you want to open a chart for? Or what exchange do you need data for? Do you need just historical data, or also real time or delayed data? If you want to use TPO Profile Charts or Numbers Bars here is the documentation: Time Price Opportunity (TPO) Profile Charts Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-28 16:42:10
