Date/Time: Sun, 09 Mar 2025 01:15:23 +0000
TransAct Futures Brokerage
View Count: 551
[2022-02-28 14:22:18]
LarryB - Posts: 2
Do I need a different Broker for Sierra
[2022-02-28 14:37:14]
LarryB - Posts: 2
I use TransAct Futures as my Broker, do I need a different one for Sierra
[2022-02-28 14:43:29]
Yes if you want to continue with Sierra Chart which we would recommend. Complete information is here:
Information for Transact Users for Versions 2354 and Higher
We can have a broker follow up with you.
[2022-02-28 14:51:16]
Stage 5 Trading - Posts: 155
Hi Larry,
As a former Infinity Broker I fully understand the trials and tribulations of changing brokerage firms and no longer being able to use the Transact AT. With that being said, Stage 5 takes great pride in helping Transact/Infinity traders transition as seamlessly as possible. Personally, I believe the best solution would be to switch to Sierra Teton Order Routing with Denali for real time and historical data. This is all maintained by Sierra directly, which I feel provides great benefits to traders as Sierra can focus on enhancements instead of maintenance of other third party order routing feeds. In addition, I feel it is the best overall quality and value for traders.
If you open an account at Stage 5 using Sierra Chart Teton Order Routing, you will receive $0.20 per side commissions on the micros and $0.45 commissions on non micros plus exchange and regulatory fees.
Please feel free to contact us and we will gladly assist you with any questions you may have and/or the process of transitioning your account and hopefully helping you improve your current trading solution. We would be able to provide some DOM chartbook layouts that will hopefully be more in line with what you are accustomed to. In addition, we would be more than happy to have a remote session to help get you setup with the new layouts.
If you have questions or would like to speak to an assigned personal broker for details, please call us at 1-312-896-9897 or 1-800-258-6675. You can email us at sierrachart@s5trading.com and can also contact us here: https://stage5trading.com/contact/
If you are ready to move to the Teton Order Routing solution right away, we invite you to complete an application by clicking the blue button at the top of the https://stage5trading.com/ page that says Introducing Sierra Chart Teton Order Routing - Click Here to Open an account
Thank you,
Anthony Giacomin
Stage 5 Trading
Trading derivatives carries a high degree of risk, and may not be suitable for all investors. Past performance is not necessarily indicative of future results.
