Date/Time: Sun, 09 Mar 2025 01:24:43 +0000
Unlinked chartbook still is linked
View Count: 596
[2022-02-28 01:56:16] |
Manerva Funding Financial - Posts: 16 |
I made a duplicate chart in the same chartbook of my TPO chart. I then went to settings and unlinked the chart however when i change to a 30 minute chart both charts change.
[2022-02-28 13:23:32] |
Did you go into Chart >> Chart Settings >> Advanced Settings 2 >> Chart Linking and set the Link Number to None? If so, the linking has been removed. When you look at the title of the Chart Settings window does it indicate that the chart is being referenced by another chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-28 15:20:13] |
Yes I have linking set to none. I do not see anything that says that however, if I try to change the chart here is what I get as an error message: "You have performed an operation which cannot be completed because this chart is being referenced by studies in other charts in the chartbook. Do you want to clear these references" When I say yes it still does not allow me to change the charts separately
[2022-02-28 18:40:19] |
John - SC Support - Posts: 38516 |
You have a study on that chart that is dependent on another chart and needs to have the same Chart Settings. You would need to determine which study it is and remove it (or change it so that it is not referencing the other chart). Refer to the following for more information: Unable to Change the Bar Time Period for Charts: Chart Being Referenced by Another Chart Preventing Bar Time Period Change For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
