Date/Time: Sun, 09 Mar 2025 01:27:26 +0000
Study doesn't work
View Count: 603
[2022-02-27 17:36:13]
User696827 - Posts: 15
Hay,
As you can see, it is a heatmap.
It works great on a laptop, but it doesn't show on a computer at all.
The study are same, was copied from DATA from laptop.
How do I solve it to see it on the computer too?
imageScreenshot (87).png / V - Attached On 2022-02-27 17:30:24 UTC - Size: 178.87 KB - 140 views
image55.png / V - Attached On 2022-02-27 17:33:32 UTC - Size: 117.03 KB - 136 views
[2022-02-27 17:39:57]
So, the problem is ,Large Volume Trade Indicator,
it doesn't show up on the computer at all but it works great on a laptop.
Thank you
[2022-02-27 17:49:38]
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
