Date/Time: Sun, 09 Mar 2025 01:45:07 +0000
Cannot adjust the font size correctly on the Volume Profile Study applied to my DOM
View Count: 613
[2022-02-27 04:34:21]
User854802 - Posts: 43
Hi
I have spent like 2 hours going over every option in the graphic settings window on my DOM and I cannot get this to work. I have a DOM with 4 columns. Bid, Price, Ask and Last Price. Onto that I applied a Volume Profile study with delta - total volume displayed. As you can clearly see, the VP text is way bigger than the DOM text. I went into the VP study settings and there are no options in there to control text size. SO I am going into the DOM chart graphic settings, and the only option that changes the size of the VP texct is the "Chart Text" option. The problem is, the VP numbers are not proportionate to the "Price" numbers. If I change the font size to like 8, then the VP numbers look good, but my price text look tiny. If I put it at 9 like in the screenshot, then the Price text is good but the VP text is huge.
Why are these number sizes disproportionate even at the same number setting under "chart text" and how can I make them all equal size?
imageScreenshot_1.jpg / V - Attached On 2022-02-27 04:28:54 UTC - Size: 655.5 KB - 145 views
[2022-02-27 11:00:24]
Refer to this Volume by Price study Subgraph setting:
Volume By Price Study: Volume Numbers Text Color and Size (SG7) (Volume Numbers Text Color and Size (SG7))
[2022-02-27 15:36:06]
Thanks! I swear I had gone into the Volume by Price settings but since the font size box was blank I thought that was not relevant to that. Got it.
