Date/Time: Sun, 09 Mar 2025 01:30:31 +0000
How to send order only to a particular chart?
View Count: 434
[2022-02-27 04:19:22] |
User318993 - Posts: 1 |
i have 2 chart open with different timezone . When the code trigger position in the 1st chart the position is also opened on the 2nd chart. Is there a way so that i can send order to a particular chart only?
[2022-02-27 10:56:47] |
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
