Date/Time: Wed, 27 Nov 2024 14:24:36 +0000
forward curve study
View Count: 684
[2022-02-27 00:43:32] |
User146848 - Posts: 121 |
Plotting a forward curve of 3 years with ALL the contracts is not practical because the lines are too close to each other in the front end. This is very visible in the energy contracts. Is there a way to select specific contract months of each single year only?
[2022-02-28 16:34:43] |
John - SC Support - Posts: 36310 |
There is not a way to select specific contracts to load for the Forward Curve study.
[2022-02-28 16:56:30] |
PLS implement this small feature...for products like crude oil its really nessecary.
[2022-02-28 16:57:58] |
There actually is by altering the contract months in the Global Symbol Settings for the symbol: Global Symbol Settings Specifically the setting is: Continuous Contract Months But this has to be tested. We would expect it to work though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-28 17:03:26] |
i tested it already and its not working. Deselectiong contract months in the global symbol settings has no effect on the study. But you will test this anyway. Best, |
[2022-02-28 17:35:53] |
Rather than doing that, select the contracts that you want in the Forward Curve study with this Symbol Settings: Continuous Contract Months Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-28 17:36:04
[2022-02-28 18:43:27] |
Nope, what i want to do is to plot the CL months Feb Apr Jun Aug Okt and Dec for the next 3 years. Its a special case, i admit that, but its nessecary for products which have a contract for almost every month.
[2023-07-28 09:21:43] |
Yeager - Posts: 125 |
AM ALSO LOOKING TO LOAD SIMILAR CURVE FOR OIL. dID ANYONE FIND A FIX? Thanks |
[2023-07-29 12:26:19] |
user_xyz - Posts: 416 |
This is, would be useful for a variety of contracts VIX, Natgas, Crude etc
