Date/Time: Sun, 09 Mar 2025 01:01:17 +0000
New NASDAQ Total View Data Feed - no right volume
View Count: 755
[2022-02-26 11:25:25]
Пользователь488020 - Posts: 100
Hello, the month of February is coming to an end, in which you suggested using the New NASDAQ Total View Data Feed in test mode. You were unable to do a full volume flow demonstration for stocks this month. Tell us what your plans are in March? What will you do next month and will the full volume be made on the shares?
imageto sch4.jpg / V - Attached On 2022-02-26 11:25:18 UTC - Size: 145.69 KB - 211 views
[2022-02-27 01:22:04]
fykemang - Posts: 49
I asked a similar question. Here is the reply I got: NASDAQ Total View Intraday Volume Data Incorrect
Date Time Of Last Edit: 2022-02-27 10:54:26
[2022-02-27 11:14:54]
Yes, it's sad! Six months of promises have passed. I subscribed in November in the hope that I would use the best software for shares, but I was deceived.
[2022-02-27 16:42:42]
Sierra Chart is providing the actual volume data from the NASDAQ TotalView data feed.
We did deliver the NASDAQ TotalView data feed like we said. We did not know that the volume for NASDAQ associated stocks, that the volume would be lower.
We are looking to add support for another feed with the complete volume. The timing of this is unknown. The NASDAQ TotalView data feed is a very good data feed as it is.
[2022-02-27 17:03:37]
Also refer to this post:
How to Use New NASDAQ Total View Data Feed | Post: 297435
