Date/Time: Sun, 09 Mar 2025 01:09:18 +0000
Exported trade data incorrect
View Count: 644
[2022-02-25 17:54:26]
JesseW - Posts: 6
When I went to export my trade data for the month, it moved the decimal point two digits to the right on the filled price.
Date Time Of Last Edit: 2022-02-25 17:55:16
Private File
[2022-02-25 18:29:46]
John - SC Support - Posts: 38516
Refer to the information here:
Trade Activity Log: Saving the Log
[2022-02-25 18:37:22]
JesseW - Posts: 6
I did, I don't see anything that says es is at 450,000 like my trade data files says it is.
[2022-02-25 18:44:15]
The price values when using the File >> Save Log As function for the Trade Activity Log, are in what is considered an adjusted format. This is with the Symbol Price Multiplier applied which usually is 1 but can be other than 1.
In the case of when using the File >> Export command, the price values are exported in an unadjusted format which means they are saved as they exist before applying the Symbol Price Multiplier.
You would need to use File >> Save As in order to get the prices in the Unadjusted format.
[2022-02-25 18:50:53]
JesseW - Posts: 6
Okay, done that. Now the Rithmic data is still the same but the new tenton order data is correct.
Date Time Of Last Edit: 2022-02-25 18:51:05
Private File
[2022-02-25 21:21:52]
When you are saving the Rithmic data you need to set Sierra Chart to Rithmic. Refer to:
Trade Activity Log: Solving Trade Activity Incorrect Price Formatting and P/L Values
