Date/Time: Sun, 09 Mar 2025 01:34:53 +0000
moving from sim to live
View Count: 506
[2022-02-25 16:11:52] |
User894546 - Posts: 47 |
I have downloaded a second version of Sierra to my PC. My first version is live and the data settings are on "SC CME Futures order routing". My second version does not have this option in the dropdown "current selected service". I believe my software is up to date, can you please advise what I need to do? Many Thanks |
[2022-02-25 17:12:27] |
John - SC Support - Posts: 38516 |
The entry is specifically named Teton CME Order Routing. Please look again and see if it is in your list. If not, then do you have anything showing up in the list for Current Selected Service? Just in case this is related to how to use the new windows, refer to the following information: Settings Windows Interface For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
