Date/Time: Sun, 09 Mar 2025 01:25:18 +0000
Problems I have with my General Settings under Global Settings
View Count: 532
[2022-02-24 20:41:47] |
User707404 - Posts: 34 |
I am trying to add and subtract certain charts to come up on my current chart book. What happens is now I cannot get to the Global Settings to add or remove or place charts in General Settings. Instead when I click on General settings it brings up commands and settings of my Sierra DOM. How do I reset this? Thanks. Robert
[2022-02-24 22:21:21] |
John - SC Support - Posts: 38516 |
Select Global Settings >> General Settings, then make sure you select the [General 1] tab at the top (an asterisk will show next to that label indicating it is the active tab). You will find the section for Open Files on Startup in the middle of that page. For more information on how to use the new windows, refer to the following: Settings Windows Interface For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-25 02:51:00] |
First thing to do is to update to the current version following these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
