Date/Time: Sun, 09 Mar 2025 01:00:31 +0000
market depth study - how to see only line above specific number ?
View Count: 551
[2022-02-24 17:51:47] |
User278398 - Posts: 291 |
Hello all, i over the documentation in the internet of market depth study but it was to difficult to understand how to get what i want... i want to see lines of market depth if there is size above specific number ( as like in DOM Graph "totals and percentages" line... but in DOM graph, i cant see what i wish for) it is possible to get in this study what i wish for? if "yes", can someone attach pic of the settings i need to change to get what i ask for if no, there is another way? thank u very much :) |
[2022-02-24 18:22:17] |
John - SC Support - Posts: 38516 |
In order to only see the Market Depth Historical Graph data where the values are above a certain amount, you would need to set the following Input: - Lowest Quantity for Coloring: Set this to the Value or Percent (depending on the Input "Value Type for Lowest Quantity for Coloring") to the value above which you want to see the data. Refer to the information here: Market Depth Historical Graph: Lowest Quantity for Coloring For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
