Date/Time: Sun, 09 Mar 2025 00:47:39 +0000
Chart updates
View Count: 463
[2022-02-24 15:25:40] |
TCDD6299 - Posts: 1 |
Hi, I just bought a Service Package, but I notice that my chart is lacking. Deleting and downloading the data does not work. Can you help me with this? Regards, https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=61694 |
[2022-02-24 16:44:50] |
John - SC Support - Posts: 38516 |
Please get us a screenshot of the chart by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage The reason we need an image using the above instructions is for us to be able to see the entire chart. There is a lot of information that can help us determine the issue by being able to see everything. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
