Date/Time: Sun, 09 Mar 2025 01:44:14 +0000
chart not connecting
View Count: 527
[2022-02-24 15:18:38] |
User229460 - Posts: 24 |
still not connecting
[2022-02-24 15:27:24] |
We would like to call to help you with this. But we called and there was no answer.
[2022-02-24 16:26:04] |
Stage 5 Trading - Posts: 155 |
Hi Trader, Stage 5 takes great pride in helping Transact/Infinity traders transition as seamlessly as possible. Personally, I believe the best solution would be to switch to Sierra Teton Order Routing with Denali for real time and historical data. This is all maintained by Sierra directly, which I feel provides great benefits to traders as Sierra can focus on enhancements instead of maintenance of other third party order routing feeds. In addition, I feel it is the best overall quality and value for traders. Below you will find a trader's experience on Teton with Stage 5. Thanks for the email. In phrase, I am over the moon based on my experiences with Stage5/Teton/Sierra. I use level 2 data, and what I have now looks rock solid. I have been using Sierra for years, and your team made the set up easy and painless. I have tested switching over, symbol changeover when changing connections is faultless. I want to spend more time with the new service, but I can tell you your team are brilliant to deal with, and compared to AMP/CQG, what you offer is much better in comparison. Over the coming months Stage5 will end up operating as my main account. Very happy to recommend to others I know. What you and Sierra can offer now is a game changer. Thanks again for reaching out. All the best Patrick If you open an account with Stage 5 Trading using Sierra Chart with Teton Order Routing, you will receive $0.20 per side commissions on the micros and $0.45 commissions on non-micros plus exchange and regulatory fees. Please feel free to contact us and we will gladly assist you with any questions you may have and/or the process of transitioning your account and hopefully helping you improve your current trading solution. We would be able to provide some DOM chartbook layouts that will hopefully be more in line with what you are accustomed to. In addition, we would be more than happy to have a remote session to help get you setup with the new layouts. If you have questions or would like to speak to an assigned personal broker for details, please call us at 1-312-896-9897 or 1-800-258-6675. You can email us at sierrachart@s5trading.com and can also contact us here: https://stage5trading.com/contact/ Both Sierra Chart and Stage 5 work closely to hopefully provide traders the best solutions and value for their unique trading goals. Thank you, Anthony Giacomin Trading derivatives carries a high degree of risk, and may not be suitable for all investors. Past performance is not necessarily indicative of future results. Testimonials are not necessarily indicative of future performance or success and may not represent the opinion of all participants. There was no compensation to the trader for this opinion. |
