Date/Time: Sat, 19 Sep 2026 17:22:58 +0000
Volume Per Trade
View Count: 1254
| [2022-02-24 15:18:17] |
| User128517 - Posts: 10 |
Hi, Is there a way to calculate the volume by price study to be based on the ratio of volume / number of trades and only plot lines when it exceeds a certain percentage based ratio? Or is there a combination of studies that can automatically plot lines on the main price graph when the volume / number of trade ratio exceeds a certain percentage at a certain price point? I.e. 2000tick chart with a simple moving average plotted on volume. When the ratio exceeds a 150% threshold based on prior bars, plot a line on the main price graph at close price? The output would be akin to this https://tlc.thinkorswim.com/center/reference/Tech-Indicators/studies-library/R-S/RelativeVolumeStDev but would auto plot lines on the main price graph. |
| [2022-02-24 15:23:20] |
No this is not exactly supported. We do have a relative volume study: Relative Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-24 15:23:40
| [2022-02-24 17:09:26] |
Thank you for the response. My brother is a software engineer who may be able to write some custom code if there is a way to do it. Is ASCII and/or SC able to accommodate the features above with a custom study?
| [2022-02-24 17:13:04] |
| John - SC Support - Posts: 47939 |
Yes, you can definitely do that. Refer to the information starting here: Advanced Custom Study Interface and Language (ACSIL) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
