Date/Time: Sun, 09 Mar 2025 01:43:19 +0000
Snap to wicks
View Count: 762
[2022-02-23 19:05:55] |
Marlin46 - Posts: 34 |
Hey, I have been using the snap feature for trendlines and was wondering is there a feature for the trendline to snap to the wick tops? Thanks. I looked and cannot seem to locate the answer to this. I am trying to use this as computer algorithm trading is so pecise it would be helpful to sanp to wicktop if that is available. Thanks so much!
[2022-02-23 22:00:23] |
John - SC Support - Posts: 38516 |
If you are drawing trendlines (i.e. using a Tool) then the ability to snap to the Top/Bottom of a wick is standard. There is the option to include the Open and Close in addition to the High/Low, if maybe that is what you are interested in. Refer to the following setting: Chart Drawing Tools: Include Open/Close In AutoSnap (Global Settings >> Tool Settings >> General >> Snapping) Otherwise, if you are wanting something specific for the Automatic Trendlines study, then you would have to modify the study to have it do what you want. Refer to the following: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies And to the following: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
