Date/Time: Sun, 09 Mar 2025 01:08:04 +0000
Naming Alerts?
View Count: 537
[2022-02-23 18:10:21] |
bdunn - Posts: 19 |
Is there a plan to be able to name Alerts? I use a ton of them and keeping up with which alert number is which sound is a bit of a pain. It would be nice to name the alert a custom name.
[2022-02-23 21:36:55] |
John - SC Support - Posts: 38516 |
You can already do this. Refer to the following: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlertNumber_UserDefinedName For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
