Date/Time: Fri, 02 Oct 2026 10:47:36 +0000
Using Sierra chart for live NYSE TICK
View Count: 1387
[2022-02-23 17:25:42]
Victor Samuel Nathan - Posts: 1
I am interested in using Sierra chart for live NYSE TICK Data. Can you please provide me with rates and how to set up the account? Also, I am writing from Ontario Canada. Hope I can access the data service from here.
Thank you.
[2022-02-23 21:31:18]
John - SC Support - Posts: 48086
You can access the data from Canada.
In terms of the cost, there are two components:
1) The Sierra Chart Package cost. This is the cost for the particular Sierra Chart package you will be using. It is up to you as to which one you need. You will need to be on Package 10, 11, or 12 in order to use the Denali Exchange Data Feed.
2) The exchange fee. This is the cost of the exchange. In your case, you will be wanting the NASDAQ TotalView exchange, which costs $16.00 USD per month for non-professionals.
To setup the Denali Exchange Data Feed with the NASDAQ TotalView data, refer to the instructions here:
Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges*
