Date/Time: Tue, 06 Oct 2026 04:51:02 +0000
Hotkey to modify text
View Count: 1030
[2022-02-23 15:39:05]
User525965 - Posts: 180
Hi, it seems there should be a way to assign a hotkey to modify text on a current drawing I have on a chart. But I can't find a way to do it anywhere. Can you assist please?
[2022-03-09 01:48:10]
Sierra_Chart Engineering - Posts: 25070
No, this is not supported.
[2022-05-08 17:46:27]
HumblyTrading - Posts: 222
Would SC consider adding this as a hotkey in an upcoming release please?
Thanks for any help!
Mike T
[2022-05-08 18:15:29]
JohnR - User831573 - Posts: 338
Although it is not a feature / native capability, you can use a keyboard/mouse macro program to do this. SC speak of one, which I use for a few purposes. AutoHotKey.
I am not an expert on AHK, just a small time user, but you should be able to accomplish what you want to do. If you choose to explore using it, my experience has been there is a good community of very smart users on their site.
Hope this helps.
JohnR
